Siemens MPI PC adapter types
日期:2006-11-27 23:48:00 来源:本站整理
Does anyone happen to know the difference between the various Generation 1 MPI cables, part numbers:
6ES7 972-0CA21-0XA0
6ES7 972-0CA22-0XA0
6ES7 972-0CA23-0XA0 ?
Weve various reports that some work with our product and others dont. I cant seem to find much info about the history or differences between them.
I dont know the history exactly.
But the earliest adapters only supported 19200 baud between the adapter and the PC.
Later adapters support both 19200 and 38400 baud.
The part # 6ES7 972-0CA23-0XA0 should be the latest version (of the serial adapter) that is used for programming (PG connection).
There should also be a model that is to be used if you have a HMI panel (OP connection). I dont know the type number for that one.
As Jesper stated the early PC Adaptor only supported 19200, but the serial number for this adapator is 6ES7 972-0CA20-0XA0, not one of the versions you list.
Im sure there are subtle differences between revisions, but using them for there intended purpose - You wouldnt notice!
