ICOP昭营最新PC/104VDX-6354
日期:2008-12-1 23:06:13 来源:中国工控网
Specifications:
SoC DM&P SoC CPU Vortex86DX- 800MHz
Real Time Clock with Lithium Battery Backup
Cache L1:16K I-Cache, 16K D-Cache, L2 Cache 128KB
Bus PC/104 standard compliant
PC-104, PC/104+ (Optional)
BIOS AMI BIOS
System Memory 256MB DDR2 Onboard
Watchdog Timer 0 & 1 Sets Software programmable from 30.5 µsec. To 512 sec. x 2
sets (Watchdog 1 fully compatible with M6117D)
VGA XGI Volari Z9s Chipset
VGA and TFT Flat Panel Interface Support
Onboard 32MB VGA Memory, support resolution up to
1280 x 1024, 16M colors
LAN Integrated 10/100Mbps Ethernet
Audio CM119 USB Audio controller
Flash Disk Support Onboard 4MB SPI Flash Disk
MSTI EmbedDisk Module (16MB and above)
I/O Interface Enhanced IDE port (UltraDMA-100/66/33) x1
RS-232 port x3
RS-232/422/485 port x1
USB port (Ver2.0) x2
Parallel port x1
16-bit GPIO port x1
10/100Mbps Ethernet port x1
Connectors 2.0mm 44-pin box header for IDE x1
2.0mm 44-pin box header for LCD x1
2.0mm 10-pin box header for VGA x1
2.0mm 10-pin box header for USB x1
2.0mm 26-pin box header for Printer x1
2.0mm 20-pin box header for 16-bit GPIO x1
2.0mm 10-pin box header for RS-232 x4
2.0mm 8-pin header for Ethernet x1
2.54mm 5-pin box header for Keyboard x1
2.54mm 5-pin box header for Mouse x1
2.54mm 4-pin header for -5V, -12V, +12V, GND, DC-in x1
2.54mm 3-pin header for RS-485 x1
2.54mm 2-pin header for Reset x1
2.54mm 7-pin header for Redundancy Signal x1(Optional)
2.54mm 2-pin header for System-Fail-SW x1(Optional)
1.25mm 6-pin wafer for JTAG x1
1.25mm 4-pin wafer for Line-out/MIC-in x2
Power Requirement Single Voltage +5V @ 740mA
Weight 90g
Board Size 90 X 96mm (3.54 x 3.77 inches)
Operating Temperature -20°C ~ +70°C
-40°C ~ +85°C(Optional)
