丹佛斯推出安全的Rte开关
日期:2008-4-22 18:19:43 来源:中国传动网
    丹佛斯新推出的耐用的、可靠的、易整修的Rte压力开关可提供与RT同样的特点,但是经过EEX批准可用于具有高危险性因素的地方。
    信任度和认可度
    对于许多压缩机生产商来说,丹佛斯RT压力开关是一个值得信任的元件,因为其安全性和可靠性而出名。由于具备手动重新安置的特点,当其它控制元件失去作用的时候,RT被推荐用于安全关闭。客户被要求应用那些通过EEX-批准的产品,用危险因数很高的地方,现在引进Rte则被设置用于满足他们的需求。
    Rte拥有CE和ATEX批准:
    CE EX II 2 G EEX ia IIC T5
    CE marked, according to EN 60947-4/-5
    CE marked, according to PED 97/23/EC category IV, safety equipment: RTE6AEW, RTE6AEB, RTE6AES
    CCC, China Compulsory Certificate
    Mehrer Kompressoren是德国一个大型的位置压缩机生产商,是第一个应用RTe.标准的公司之一。Mehrer已经是丹佛斯RT开关的用户,但是需要由EEX-核准的开关,用于有可燃气体和蒸汽出现的生产过程中。丹佛斯通过开发配有说明的EEX核准的Rte回应其客户,使其成为安全的处理易爆气体的理想选择。
    Rte可被当作一个温度开关,压力开关及差压开关使用。更多技术说明请登录网站。
    Mehrer采用EEX核准的RT用于支持他们以前采用的由另一个厂家供应的开关,由于其可以很容易且很快地安装。其所需的装线和调整时间非常的少。
    丹佛斯一直试图回报他们的客户需求,利用RTe,一款崭新的用于提高产量的已经被用在投资解决方案中,并已经从用户处收到了积极的反馈。Mehrer Kompressoren对此Rte非常的满意。
    在丹佛斯EEx-批准系列产品中,用户还可以发现阀门,压力和温度传送器和温度传感器。
 original text
 Switch to safety when explosions are a risk
    Durable, reliable, and easy to adjust – the RTe pressure switch offers the same features as the RT – but now has EEX approval for use in areas with high risk of explosion.
    Trusted and approved
    For many compressor manufacturers, the Danfoss RT pressure switch is a trusted component, renowned for its safety and reliability. With a manual reset feature, the RT is recommended for safety shut-offs – often where other controls have failed. The customers were requesting an EEX-approved version of this product for use in situations where explosions are a risk factor – and now the introduction of the RTe is set to meet their demands.
    The RTe has CE and ATEX approvals:
    Mehrer Kompressoren, a large German manufacturer of piston compressors, was one of the first companies to adopt the RTe. Mehrer were already using Danfoss RT switches, but needed EEX-approved switches for situations where flammable gases and vapours are present in their production processes. Danfoss responded to its customer’s needs by developing the EEX-approved RTe with specifications such as metal housing, which make it ideal for handling explosive gasses safely.
