艾默生推出第一个四电极传感器
日期:2008-7-2 0:11:37 来源:中国传动网
    艾默生推出第一个四电极传感器,该传感器允许CIP导电性通过单个传感器进行测量。
    Rosemount分析模型410VP可在清洁设备应用中适用于宽泛的导电性测量。
    艾默生的Rosemount分析模型410VP四电极导电性传感器是用于生命科学和食品餐饮行业PUR-Sense家族传感器的最新版。
    高清晰度成像
    加州IRVINE 2008年6月25日消息,艾默生过程管理公司推了出了Rosemount Analytical Model 410VP四电极导电性传感器,PUR-Sense传感器家族的最新版,适用于生命科学和食品餐饮行业。传感器宽泛的动态范围
    替代的两个传感器,一个用于测量高传导率清洁解决方案,另一个测量低传导率的漂洗水,单个的410VP是第一个单独的四电极传感器,可完成CIP传导率测量。结果是初始成本低,传感器和分析器占用的空间小,还可以减少维护和培训需求。除CIP监测外,传感器还可被用于监测色谱分离层分离洗提液的传导率,探测液体界面。
    在Model 410VP传感器中所有的易潮塑料和人造橡胶都符合FDA食品规章,所有的受潮面除电极外,都有16微英寸(0.4微米)的Ra末道漆。传感器设计用于满足3A和EHEDG卫生标准,并有1-1/2 英寸和2英寸三角夹。
    Model 410VP传感器与Pt1000RTD相结合,用于温度补偿。RTD通过一个不锈钢界面与样品相接触,所以对温度的响应速度特别快。该传感器还与艾默生Model 1056智能分析仪相兼容。
 original text
 Emerson launches first four-electrode sensor that allows CIP conductivity measurement with a single sensor
    Rosemount Analytical Model 410 VP applicable for wide ranging conductivity measurements in sanitary applications
    Emerson‘s Rosemount Analytical Model 410VP four-electrode conductivity sensor is the latest addition to the PUR-Sense family of sensors for the life sciences and food & beverage industries.
    High-resolution image
    IRVINE, Calif., June 25, 2008 — Emerson Process Management introduces the Rosemount Analytical Model 410VP four-electrode conductivity sensor, the latest addition to the PUR-Sense family of sensors for the life sciences and food and beverage industries. The wide dynamic range of the sensor (1 uS/cm to 1400 mS/cm), makes it ideal for clean-in-place (CIP) monitoring.
    Instead of two sensors, one to measure the high conductivity cleaning solution and the other to measure the low conductivity rinse water, a single Model 410VP is the first single four-electrode sensor that does the complete CIP conductivity measurement. The result is lower initial cost, less space taken up by sensors and analyzers, and reduced maintenance and training requirements. In addition to CIP monitoring, the sensor can be used to monitor the conductivity of eluents in chromatographic separations and to detect liquid interfaces.
