NI推出1GHz带宽PXI数字转换器
日期:2008-8-4 21:24:23 来源:中国传动网
    新模块在自动化测试应用中传递了用于高带宽测量的最优化性能。
    2008年7月28日消息,NI于当天宣布PXI-5154数字转换器/基于PC的示波镜,使家族产品的高速高清晰度高信道产品增加至20种。双信道的1 GHz PXI-5154数字转化器提供高达2 GS/s的实时采样率(对于重复信号采样率为20GS/s),使其成为获得和描述快速、十亿分之一秒速度的理想选择。每个频道安装有很大的车载内存,可达256MB,数字转换器还可提供高持续不变的采样率,扩大数据捕捉窗口。设备非常适用于在消费类电子、半导体、航空防御和生命科学行业的自动化测试和数据流应用。
    利用NI获专利的T-Clock技术,工程师们可将PXI数字转化器与多种NI硬件相融合,定制和构建一个完整的、自动化的多信号测试系统。利用T-Clock技术,工程师们还可以同步多个PXI-5154数字转化器,在单个PXI底盘上组建高达34信道的系统,各个模块之间同步的采样率可达1GS/s,精确度达到皮秒级。数字转换器的高带宽和tight 多模块同步尤其对应用有益,包括质谱测量、雷达、智能信号、非破坏性测试和高信道计算的物理实验。
    工程师们可将新数字转化器与NI LabVIEW Express software软件相结合,快速得到数据,执行测量,并在Microsoft Excel中分析。此外,PXI-5154数字转化器与所有的NI仪器想结合工作,如:LabVIEW和LabWindows/CVI及其它开发环境,如ANSIC,Microsoft C++和Visual Basic.
    更多关于新数字转化器信息,可登陆visit www.ni.com/digitizers  查看。
original text
National Instruments Introduces 1 GHz Bandwidth PXI Digitizer
    New Module Delivers Optimized Performance for High-Bandwidth Measurements in Automated Test Applications
    NEWS RELEASE – July 28, 2008 – National Instruments today announced a significant bandwidth increase in its digitizer offering with the introduction of the NI PXI-5154 digitizer/PC-based oscilloscope, expanding the family of more than 20 high-speed, high-resolution and high-channel-count products. The dual-channel, 1 GHz PXI-5154 digitizer offers up to a 2 GS/s real-time sample rate (20 GS/s equivalent-time sample rate for repetitive signals), making it ideal for acquisition and characterization of fast, nanosecond-edge speeds. Equipped with the deepest onboard memory in its class of up to 256 MB per channel, the digitizer also provides high sustained sample rates over extended data capture windows. The device is well-suited for automated test and data streaming applications in the consumer electronics, semiconductor, aerospace/defense and life sciences industries.
    Using National Instruments patented T-Clock technology, engineers can integrate PXI digitizers with a variety of NI hardware – including arbitrary waveform generators and digital waveform generators/analyzers – to customize and build a complete, automated mixed-signal test system. Using T-Clock technology, engineers also can synchronize multiple PXI-5154 digitizers to build systems with up to 34 channels in a single PXI chassis, all simultaneously sampling at 1GS/s and synchronized to picosecond-level accuracy between modules. The digitizer’s high bandwidth and tight multi-module synchronization are particularly beneficial for applications including mass spectrometry, radar, signal intelligence, non-destructive test and high-channel count physics experimentation.
上一篇: 九洲获7000万美元机顶盒订单
下一篇: 没有了
