艾讯宏达科技有限公司最新推出凌动处理器Mini-ITX主板SYS76833
日期:2009-2-27 14:12:09 来源:中国工控网
艾讯宏达最新推出凌动处理器Mini-ITX主板SYS76833
产品特点:
1、 板载英特尔凌动230处理器(1.6G/4W),FSB400MHz
2、Intel 945GSE+ICH7芯片组
3、最大支持2GB的DDR2 533/667MHz内存
4、 英特尔GMA950图形媒体加速器,最大共享内存224M
5、支持24bit LVDS,支持双显示
6、Realtek RTL8111C千兆网卡
7、2个SATAII硬盘接口,支持RAID0/1
8、6个串口,5个RS-232,1个RS-232/422/485接口
9、PCI扩展槽
技术规格:
Item
Description
CPU Type
Onboard Intel smallest and lowest Atom 230 processor
CPU Frequency
1.6G
Chipset
Intel 945GC + ICH7 with FSB 400MHz
Memory
1 x SO-DIMM(200pin) socket, Support DDR 533/667 up to 2G
BIOS
Award 8Mbit PnP with VGA BIOS
Display
Inetel Graphics Media Acdelerator(GMA) 950 max share 224M memeory
LVDS Interface
Support 24bit dual channel LVDS
LAN
Realtek RTL8111C 10/100/1000M Base-T
USB
8 x USB2.0
HDD Interface
1x IDE,2 x SATA II
RAID
RAID 0/1
Serial Port
6 x COM Ports,COM1 for RS232/422/485,COM2-5 for RS232
Parallel Port
1 x ECP/EPP/SPP Support
Keyboard/Mouse
PS/2 and pin-header connector for mouse and keyboard
Watchdog
System reset or non-maskable interrupt software programmable time internal and jumper selectable 255 level
Audio
Realtek ALC 662 with Line-in / Line-out / MIC
Expansion Components
1 x 32bit PCI expansion slot
Power Supply
Standard ATX power
Operation Temperature
0℃~ 60℃
Operation Humidity
-40℃ ~ 85℃
Dimension(LxW)
170mm x 170mm
