Configurable motion helps OEMs
日期:2008-3-13 0:25:51 来源:中国传动网
    ACS Motion Control开发了一个基于模块控制系统的机架,此系统可以控制高达八个机架伺服驱动及通过CANopen的64个分布式轴。
    MC4U过程控制系统设计用于多轴过程控制应用,用于多性能结合,支持多轴运动,灵活的驱动配置,PLC过程逻辑控制和便利的包装。MC4U结合控制器、驱动器、电源和增加的I/O,提供机械自动化功能控制。应用包括:OEM生产,测试,设备监测,半导体,电子件装配,通用自动化,医疗和平板显示器。小容量需求的快速原型由标准的插入件,单个主板,外部网络部件,标准机架安装附件,前入口面板/机架固定件组成,交付时间在收到订单后的一到两周内。
    可配置选项提供了一个低成本途径,可整合特殊客户的需求。如标准件,标准机架固定附件,用于客户需求的特殊主板,不用手工布线,用户可使用喜欢的接连器和固定件入口,带有后向和前端入口的机架固定件,带有前端入口的安装面板附加用户插卡。
    ACS公司副总裁Evan Reed说:“我们的MC4U是一个平板机架安装系统,其符合所有多轴过程控制的需要,仅需要很短的开发时间,还能降低风险和成本。MC4U系统不用折中精确性和生产量就能实现应用需求的管理。”
    系统整合了特殊设计的电源,高性能的PWM驱动板块,表现为现行的匀速循环数字控制,拥有排除抖动的线性驱动,减轻噪音的三相电机过滤器。结合公司的SPiiPlus CM控制模块,通过排除每个轴上的智能控制器需求,从而消减了2轴到8轴的控制成本。主机不再需要管理网络,并与单个MC4U系统相连接。ACS软件工具提供了简单的安装,调整和试运行及模拟应用,可以下载免费的模拟器。
 original text
    Plymouth, MN – ACS Motion Control developed a rack-based modular control system that can control up to eight rack servo drives and 64 distributed axes via CANopen.
    The MC4U motion control system is designed for multi-axis motion control applications for a combination of performance, multiple support axes, flexible drive configuration, PLC motion and logic control, and convenient packaging. MC4U integrates controllers, drives, power supplies and additional I/O and networking capability to provide control of machine automation functions. Applications include OEM production, test or inspection equipment, semiconductor, electronic assembly, general automation, medical, and flat panel display. A fast prototype for low volume needs consists of standard plug-in components, mating individual motherboards, external network components, standard rack-mount enclosure, and front access panel/rack-mount, with a delivery time of one to two weeks after receipt of order.
    Custom configuration options provide a lower unit cost approach and integrate specific customer requirements, such as standard components, standard rack-mount enclosure, specially designed motherboard for customer needs, elimination of manual wiring, customer-preferred connectors, customer-preferred mounting and access, rack-mount with back or front access, panel-mount with front access, and the addition of customer‘s plug-in cards.
