阿尔斯通为德国RWE电厂提供非常高级的清洁煤燃烧技术
日期:2008-4-26 18:23:44 来源:中国传动网
    阿尔斯通宣布经获得一项合同:为位于德国西北部Hamm镇附近的Westfalen燃煤型电厂的两个800WW机组提供锅炉,该电厂由RWE Power AG.运营,两个新燃煤机组在世界上将是最清洁且最有效的机组。
    该合同价值约有5亿欧元,阿尔斯通将提供完整的锅炉和辅助设备,包括建站和试运转。当在2011年完工时,新机组将实现46%的循环效率,是现存的烟煤燃烧型电厂效率的36%。
    新Westfalen超临界锅炉的温度可达600°C,将减少所有的气体释放,包括二氧化碳在内,与以前老机组相比,将减少三分之一的排放量。由于采用阿尔斯通的高级技术解决方案,氮的氧化物与硫的氧化物都会明显减少。除了出众的环境保护优势之外,阿尔斯通的高效超临界技术提供了低燃烧成本,操作灵活性和高实用性。
    RWE Power AG的CEO Dr. Johannes Lambertz说:“在Hamm,我们正在建立一个非常高级的燃煤电厂,该厂建成之后,与原来的旧机组相比,每年在发电的同时减少250万吨CO2的排放量。在阿尔斯通,我们已经建立了一个有能力的且经验丰富的小组,用以执行大量的发电类项目。”
    阿尔斯通是世界领先的锅炉技术供应商,在全球范围内已经安装了的锅炉总输出功率超过420,000 MW。阿尔斯通还是超临界锅炉技术的领先提供商,在世界范围内提供的或是许可证许可的总功率输出约有150,000 MW。
    阿尔斯通电力系统总裁Philippe Joubert说:“作为一个清洁燃煤技术的全球领先者,阿尔斯通拥有专门的技术知识,利用这些,可在提供非常清洁的电力技术的同时满足客户的特殊需求。”
 original text
 Alstom to supply most advanced clean coal combustion technology to RWE power plant in Germany
    Alstom has won a contract to supply the boilers for two 800 MW units at the existing coal-fired Westfalen Power Station, located in the North-Western part of Germany near the town of Hamm and operated by RWE Power AG. The two new bituminous coal-fired units will be  among  the cleanest and most efficient in the world.
    Under the terms of the contract, the value of which is approximately 500 million euros, Alstom will supply the complete boiler islands and auxiliary equipment, including erection and commissioning. When completed in 2011, the new units will achieve cycle efficiencies of about 46%, substantially more than the European average of 36% efficiency for existing bituminous coal-fired plants.
    The new Westfalen supercritical boilers with steam temperatures of 600°C will reduce all emissions, including carbon dioxide (CO2), by about one-third compared to the fleet of older units. Thanks to the application of Alstom’s advanced technical solutions, the levels of nitrogen oxide (NOx) and sulphur dioxide (SO2) emissions will be reduced very significantly. In addition to superior environmental performance, Alstom’s high-efficiency supercritical technology provides lower fuel costs, operating flexibility and high unit availability.
