丹佛斯推出以节省成本为目的的MBS3000传送器
日期:2008-2-6 0:36:42 来源:中国传动网
    我们周围的空气虽然是无偿使用的,但将其处理成工业应用的气体时就变得很昂贵。由丹佛斯提供的压力传送器控制的空气助推器可帮助降低成本。
    优化的空气压缩设备能节省成本并提高效率.
    空气压缩是现代工业生产的必不可少的因素,无论是在人力资源节省上还是在自身生产过程中。但是由于许多压缩机工作效率低于20%,所以这些机器必须努力工作以根据用户说明保证空气体积和持续不断的压力供应。
    当然,空气压缩机工作的越多消费的成本就越多,同样,能量消耗和内部零件的损耗都将存在。
    为了降低压缩机的负载和附随的成本,生产商们可以在中层加一个空气助推器,以推动空气,实现所需要的压力,保证关键设备保持稳定的供应。
    除去精确的控制,但是空气助推器不能有效地实现功能,所以许多生产商们转向了丹佛斯的压力传送器。理想的选择是紧凑的压力传送器MBS3000,其设计可用于几乎所有的工业应用,甚至是在很苛刻的环境条件下都能提供可靠的压力测量。
    灵活的压力传送器设计覆盖了不同的输出信号,绝对的和相关尺度版本。测量范围从0-1 到0-600 bar.
    卓越的震动稳定性、健全的设施和高度EMC/EMI保护都将安装在传送器上以满足非常严格的工业需求。
    对于在亚洲的一些领先的压缩机和空气助推器生产商,MBS 3000是理想的选择。
 original text
 Keeping the pressure on cost savings
    While the air around us may be free, harnessing it for use in industrial applications can be expensive. An air booster controlled by a Danfoss pressure transmitter can help reduce costs.
    Optimising air compressor equipment saves money and boosts efficiency
    Compressed air is a vital element of modern industrial production, whether in labour-saving tools or in the production process itself. But with many compressors working at less than 20 percent efficiency, they have to be worked hard to ensure that air volume and pressure remain constant and according to the user‘s specification.
    And of course, the harder a compressor works the more it costs - both in terms of energy consumed and in wear and tear on internal components.
    To reduce the load on compressors and reduce the accompanying costs, manufacturers can add an air booster at an intermediate stage to ‘boost‘ the air to the required pressure and ensure a stable supply to critical equipment.
    Without precise control, however, air boosters won‘t function effectively and so many manufacturers turn to Danfoss’ range of pressure transmitters. A typical choice is the compact pressure transmitter MBS 3000, which is designed for use in almost all industrial applications and offers a reliable pressure measurement, even under harsh environmental conditions.
